Hydraulicspneumatics 1038 Fig1 13
Joystick controls
Jan. 1, 2012
New interfaces expand possibilities for this popular control component.
Manufacturers and operators of mobile equipment like joystick controls because they give the operator a feel for his command - the greater the displacement of joystick, the greater the response from the actuator. Some approaches to interfacing hydraulic valves with joysticks include:
  • mechanical linkages,
  • hydraulic pilot circuits, and
  • electrical commands to electrohydraulic valves.
With mechanical linkages for commanding hydraulic valves via dual-axis joysticks, the apparent disadvantage is the complexity of the linkage arrangement, making it difficult to install and adjust. The simplest linkages are levers and rods, but these become cumbersome if a straight path from the joystick to the hydraulic component does not exist. When the mechanical linkage must be routed over, under, around, or through obstacles, mechanical push-pull cables have found favor.
All mechanical linkages may require operators to generate objectionable high actuating forces if the mechanical advantage of the assembly is not designed in. Otherwise, operator fatigue may result. And as with all mechanical arrangements, regular lubrication and adjustment for wear may be necessary. A neater arrangement uses hydraulically piloted valves and joysticks. With this setup, low-pressure fluid is routed to the joystick, which, in turn, routes fluid to the appropriate pilot-operated hydraulic devices based on joystick position The advantages of this system over a mechanical linkage arrangement are simplified installation, lower actuating force required by the operator, and less maintenance.
Among the disadvantages of piloted joysticks are the potential for leakage, noise, and heat from hydraulic fluid in close proximity to the operator. In winter weather, cold oil adversely affects response and increases operator effort. Hydraulic pilot installation still involves the routing of multiple hoses or soft-metal tubing.
Fig. 1. Potentiometric movement joysticks. If the joysticks handgrip has significant mass, machine vibration will cause potentiometer to wear out quickly because cycles accumulate with the same frequency as the vibration.
An electric joystick uses a power supply and sends electric signals to command an electrohydraulic valve. Because thin wires are so much easier to route through a machine than mechanical cables, hoses, or tubing is electric joysticks greatly simplify installation and and provide the freedom of remote mounting. Serial communications make this process even easier. The valves can be located extremely far from the joystick. The principal disadvantage of the electric joystick has been the higher cost of electrohydraulic valves over their manually driven or pilot-operated counterparts. The cost trade-off between hydraulic and electric joysticks is about even.
Electric joysticks
There are two major categories of electric joysticks displacement and non-displacement. The displacement type uses the motion of a lever, transducing that motion eventually into an electrical output. The non-displacement type has a lever similar to the displacement type. However, the motion of the joystick is not transduced directly to an electrical output. Instead, the force applied to the lever is transduced via a strain gage or similar medium to electrical output. An advantage of the non-displacement joystick is the absence of moving parts. A disadvantage is the loss of tactile feedback to the operator normally associated with the motion of a joystick.
Fig. 2. Relationship of primary and secondary coils. Primary coil is driven by a 20-kHz signal. With each collapse of every cycle of the primary field, flux flow establishes an induced voltage in each of the secondary coils. If the primary coil is centered above the secondary coils, the induced voltage in each coil is equal. As the primary moves away from the center, a differential in induced voltage occurs in each coil.
The two popular designs of displacement-type joysticks are potentiometric movement and inductive coupling. The potentiometric joystick, Figure 1, uses a rotary or linear potentiometer to convert mechanical displacement to electrical output. The conversion from curvilinear motion of the joystick lever to potentiometer movement usually involves shafts, gimbals, gears, and torsion springs. These mechanisms contain many parts, which can make these joysticks vulnerable to damage and shortened lifespan - especially if they are exposed to machine vibration.
Potentiometric joysticks are available in high-cycle-life construction with published life in excess of 106 full cycles. Most joysticks spend the greater part of their working lives in a neutral position, with the wipers of their pots being dithered continuously due to the vibration of the machinery onto which they are mounted and the mass of the control levers. This low amplitude cycling (dithering) of the pot wiper may prove more destructive to the pot than full-cycle stroking would. The constant dithering and high accumulation of cycles over a narrow area may cause the conductive element to wear-in locally, causing a "dead" or "noisy" spot.
Inductively coupled movement
An inductively coupled joystick uses a variable-transformer-type relationship. A primary coil sets up a field that is induced into a set of secondary coils. Through movement of either the drive coil or a ferrous shaft, which commutates the field, the induced field will vary proportionally. The closer the drive coil is to a secondary coil, the stronger the pickup field. The secondary coil that is farther away from the primary coil will have a proportionally smaller pickup. Figure 2 shows the relationship of primary and secondary coils.
The principal advantage of this mechanism is that there are no contacting or wiping electrical parts. Further, the mechanical complexity is much less. The model shown in Figure 2 has only three moving parts (lever, centering cup, and helical compression spring), so life of the control is significantly extended.
Protection from stray electrical fields affecting the joysticks inductive field is provided by a synchronous detection system. The pickup from the four secondary coils must equal the induced signal provided by the primary, so the effects of adjacent electrical fields essentially are ignored.
Hall-effect technology
Fig. 3. Current flows uniformly through a conductor when no magnetic field is present.
Development of newer joystick technology has focused on enhancing linearity and electromagnetic immunity while providing additional output capabilities within a smaller working envelope. One significant technology - the Hall effect - has emerged as being completely capable of providing all these desired attributes and enhancements.
If a magnetic field is present when an electrical current flows through a conductive material, the electrons are uniformly distributed throughout the conductor, Figure 3. Introducing a magnetic field to the electric current disrupts the current and causes its course to be changed, Figure 4.
Fig. 4. Introducing a magnetic field to the current flowing through the conductor alters current flow, which creates a Hall voltage.
When the input current is held constant, as in a joystick application, the Hall voltage is directly proportional to the perpendicular component of the magnetic field. Therefore, if the magnets change position, the voltage changes and can be quantified as joystick movement.
Additional axes
The mechanical simplicity of the inductively coupled joystick movement lends itself to incorporation of multiple movement axes. The traditional two-axis joystick can have a third or even a fourth axis added to it, retaining the basic mechanical simplicity, yet having no wiping contacts. For example, a twist movement of the handgrip may produce a third axis, and a thumb-operated wheel can provide a proportional fourth axis. A grip-mounted switch could also be incorporated to add simple functionality.
Joysticks with inductively coupled movement have been replacing the more traditional models on continuous duty cycle applications - such as large excavators used in strip mines. These applications and other have found electric joysticks, particularly the inductively coupled type, to enhance their reliability.
Joysticks with inductively coupled movement have been replacing the more traditional joysticks on continuous duty cycle applications - such as large excavators used in strip mines and aerial basket controls for utility trucks using fiber-optic couplings. These and other applications have found electric joysticks, and more particularly the inductively coupled type, to enhance their reliability.
This information was provided by Douglas D. Schumann, president, P-Q Controls Inc., Bristol, Conn.
Joysticks are a popular control option
Oct. 1, 2002
Interfaces expand the possibilities for this popular control component. Manufacturers and operators of mobile equipment like joystick controls because they give the ...
Hydraulic Control Response: How Fast Is 'Fast'?
Sept. 15, 2015
At a seminar I attended on CAN-bus control systems (CAN is a protocol for the transmission and processing of control and sensor information over a 'bus' cable on automotive and...
May 15, 2024
